versuche gerade verzweifelt das cam-modul was mit dem Flachbandkabel direkt an Raspb abgesteckt wird zum Laufen zu bringen.
Irgendwie hatte ich schon mal ein Bild. Keine Ahnung wieso es jetzt nicht mehr geht (hatte zwischendrin heimcontrol.js installiert)
rufe ich den browser mit meineip:8080 auf bekommt er keine Verbindung obwohl laut Ports dort gelauscht wird
rufe ich meineip:8081 auf dann erhalte ich im Browser
Motion mmaltest Running [1] Threads
All
im motion.log steht
[1] [ALR] [VID] [Apr 07 20:46:18] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 1280 x 720 at 2 fps
[1] [ALR] [VID] [Apr 07 20:46:18] mmalcam_start: MMAL Camera using video capture
die motion.conf gibt via Browser das aus
daemon = on
process_id_file = /var/run/motion/motion.pid
setup_mode = off
logfile = /tmp/motion.log
log_level = 2
log_type = all
videodevice = /dev/video0
v4l2_palette = 7
input = -1
norm = 0
frequency = 0
rotate = 0
width = 1280
height = 720
framerate = 2
minimum_frame_time = 0
netcam_url = (not defined)
netcam_userpass = (not defined)
netcam_keepalive = off
netcam_proxy = (not defined)
netcam_tolerant_check = off
filecam_path = (not defined)
mmalcam_name = vc.ril.camera
mmalcam_control_params = (not defined)
mmalcam_use_still = off
mmalcam_raw_capture_file = (not defined)
auto_brightness = off
brightness = 0
contrast = 0
saturation = 0
hue = 0
roundrobin_frames = 1
roundrobin_skip = 1
switchfilter = off
threshold = 1500
threshold_tune = off
noise_level = 32
noise_tune = on
despeckle_filter = EedDl
area_detect = (not defined)
mask_file = (not defined)
smart_mask_speed = 0
lightswitch = 0
minimum_motion_frames = 1
pre_capture = 2
post_capture = 2
event_gap = 60
max_movie_time = 3600
emulate_motion = off
output_pictures = best
output_debug_pictures = off
quality = 75
picture_type = jpeg
ffmpeg_output_movies = on
ffmpeg_output_debug_movies = off
ffmpeg_timelapse = 0
ffmpeg_timelapse_mode = daily
ffmpeg_bps = 500000
ffmpeg_variable_bitrate = 5
ffmpeg_video_codec = msmpeg4
ffmpeg_deinterlace = off
use_extpipe = off
extpipe = (not defined)
snapshot_interval = 0
locate_motion_mode = off
locate_motion_style = box
text_right = %d.%m.%Y\n%T
text_left = HofCam
text_changes = off
text_event = %Y%m%d%H%M%S
text_double = on
exif_text = (not defined)
target_dir = /mnt/camshare/Cam1
snapshot_filename = %v-%Y%m%d%H%M%S-snapshot
picture_filename = %v-%Y%m%d%H%M%S-%q
movie_filename = %v-%Y%m%d%H%M%S
timelapse_filename = %Y%m%d-timelapse
ipv6_enabled = off
stream_port = 8080
stream_quality = 50
stream_motion = on
stream_maxrate = 4
stream_localhost = off
stream_limit = 0
stream_auth_method = 0
stream_authentication = (not defined)
webcontrol_port = 8081
webcontrol_localhost = off
webcontrol_html_output = on
webcontrol_authentication = (not defined)
track_type = 0
track_auto = off
track_port = (not defined)
track_motorx = 0
track_motorx_reverse = off
track_motory = 0
track_motory_reverse = off
track_maxx = 0
track_minx = 0
track_maxy = 0
track_miny = 0
track_homex = 128
track_homey = 128
track_iomojo_id = 0
track_step_angle_x = 10
track_step_angle_y = 10
track_move_wait = 10
track_speed = 255
track_stepsize = 40
quiet = on
on_event_start = (not defined)
on_event_end = (not defined)
on_picture_save = (not defined)
on_motion_detected = (not defined)
on_area_detected = (not defined)
on_movie_start = (not defined)
on_movie_end = (not defined)
on_camera_lost = (not defined)
sql_log_picture = on
sql_log_snapshot = on
sql_log_movie = off
sql_log_timelapse = off
sql_query = sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
database_type = (not defined)
database_dbname = (not defined)
database_host = localhost
database_user = (not defined)
database_password = (not defined)
database_port = 0
video_pipe = (not defined)
motion_video_pipe = (not defined)
thread = No threads
irgendwo scheint habe ich was falsch eingestellt
Weiß jemand Rat?
Gruß Jürgen
