nachdem ich mich durch unendlich viele logs gelesen habe hatte ich den vermeintlichen rechtschreibfehler "/../keays/.."
dann gefunden. Mit dem Gefühl endlich am Ziel zusein folgte ein
der mir aber "[FAIL] Starting virtual private network daemon: client openvpn server failed!" an den kopf warf.
meine syslog zeigt:
Mar 29 19:02:49 raspberrypi dhclient: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Mar 29 19:02:49 raspberrypi dhclient: DHCPACK from 192.168.0.1
Mar 29 19:02:50 raspberrypi dhclient: bound to 192.168.0.2 -- renewal in 1356 seconds.
Mar 29 19:08:00 raspberrypi ntpd[2107]: Deleting interface #8 tun0, 10.8.0.1#123, interface stats: received=0, sent=0, dropped=0, active_time=1596 secs
Mar 29 19:08:00 raspberrypi ntpd[2107]: peers refreshed
Mar 29 19:08:02 raspberrypi ifplugd(tun0)[25506]: Link beat lost.
Mar 29 19:08:02 raspberrypi ifplugd(tun0)[25506]: Exiting.
Mar 29 19:08:02 raspberrypi ovpn-client[25816]: OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Apr 28 2012
Mar 29 19:08:02 raspberrypi ovpn-client[25816]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mar 29 19:08:02 raspberrypi ovpn-client[25816]: Cannot load certificate file client.crt: error:02001002:system library:fopen:No such file or directory: error:20074002:BIO routines:FILE_CTRL:system lib: error:140AD002:SSL routines:SSL_CTX_use_certificate_file:system lib
Mar 29 19:08:02 raspberrypi ovpn-client[25816]: Exiting
Mar 29 19:08:03 raspberrypi ifplugd(tun0)[25843]: ifplugd 0.28 initializing.
Mar 29 19:08:03 raspberrypi ifplugd(tun0)[25843]: Using interface tun0/00:00:00:00:00:00 with driver <tun> (version: 1.6)
Mar 29 19:08:03 raspberrypi ifplugd(tun0)[25843]: Using detection mode: SIOCETHTOOL
Mar 29 19:08:03 raspberrypi ifplugd(tun0)[25843]: Initialization complete, link beat detected.
Mar 29 19:08:03 raspberrypi ifplugd(tun0)[25843]: Executing '/etc/ifplugd/ifplugd.action tun0 up'.
Mar 29 19:08:04 raspberrypi ifplugd(tun0)[25843]: client: Ignoring unknown interface tun0=tun0.
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Apr 28 2012
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: Diffie-Hellman initialized with 1024 bit key
Mar 29 19:08:04 raspberrypi ifplugd(tun0)[25843]: Program executed successfully.
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: TLS-Auth MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: Socket Buffers: R=[163840->131072] S=[163840->131072]
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: TCP/UDP: Socket bind failed on local address [undef]: Address already in use
Mar 29 19:08:04 raspberrypi ovpn-server[25847]: Exiting
Mar 29 19:08:04 raspberrypi ntpd[2107]: Listen normally on 9 tun0 10.8.0.1 UDP 123
Mar 29 19:08:04 raspberrypi ntpd[2107]: peers refreshed
Cannot load certificate file client.crt ist er erste fehler der mir auffällt allerdings habe ich keine Ahnung von wo aus die client.crt angefordert wird (um das verzeichnis zu ändern). Oder wo die client.crt zu sein hat, um sie evt. zu ergänzen (wie?)
tcp/udp: socket bind failed on local address [undef]: Adress already in use scheint dann das nächste (folge- ?) problem zu sein. Habe ich da (wo?) eventuell etwas falsch eingetragen, oder sind netzwerkkonfigurationen zu ändern?
wäre über Hilfe sehr erfreut ich prügel mich schon seit längerem mit dieser configuration rum und jeden tag wünsche ich mir ein laufendes vpn auf meinem raspberry (soll ganz normal vom inet aus übern raspberry ins homenetz)
Danke Schonmal
Sarbot
