ich versuche schon länger mein TV-Stick Pinnacle PCTV 340e Se unter Raspbian mit TVheadend zum laufen zu bringen, leider bisher ohne Erfolg.
Mit Me-TV läuft der Stick problemlos!
Unter TV-Headend wird der Stick nicht angezeigt, so sieht dies aus:
Die Ausgabe erhalte ich unter lsusb:
Bus 001 Device 005: ID 2304:023e Pinnacle Systems, Inc. PCTV 340e SE
Die Ausgabe erhalte ich unter dmesg:
[ 3.330221] usb 1-1.3: Product: PCTV 340e SE
[ 3.336099] usb 1-1.3: Manufacturer: YUANRD
[ 3.342658] usb 1-1.3: SerialNumber: 0600F39CAF
[ 13.079098] EXT4-fs (mmcblk0p2): recovery complete
[ 13.644828] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 13.656818] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 14.698604] devtmpfs: mounted
[ 14.703796] Freeing unused kernel memory: 144K (c0572000 - c0596000)
[ 16.075901] udevd[157]: starting version 175
[ 18.189342] dvb-usb: found a 'Pinnacle PCTV Hybrid Stick Solo' in cold state, will try to load a firmware
[ 18.292115] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 18.524804] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[ 19.236380] dib0700: firmware started successfully.
[ 19.769444] dvb-usb: found a 'Pinnacle PCTV Hybrid Stick Solo' in warm state.
[ 19.780914] dvb-usb: will pass the complete MPEG2 transport stream to the sof tware demuxer.
[ 19.792907] DVB: registering new adapter (Pinnacle PCTV Hybrid Stick Solo)
[ 20.682685] usb 1-1.3: DVB: registering adapter 0 frontend 0 (DiBcom 7000PC). ..
[ 20.718624] xc4000 1-0061: creating new instance
[ 20.730667] xc4000: Successfully identified at address 0x61
[ 20.738007] xc4000: Firmware has not been loaded previously
[ 20.789246] Registered IR keymap rc-dib0700-rc5
[ 20.806866] input: IR-receiver inside an USB DVB receiver as /devices/platfor m/bcm2708_usb/usb1/1-1/1-1.3/rc/rc0/input0
[ 20.822670] rc0: IR-receiver inside an USB DVB receiver as /devices/platform/ bcm2708_usb/usb1/1-1/1-1.3/rc/rc0
[ 20.836555] dvb-usb: schedule remote query interval to 50 msecs.
[ 20.849270] dvb-usb: Pinnacle PCTV Hybrid Stick Solo successfully initialized and connected.
[ 20.876396] usbcore: registered new interface driver dvb_usb_dib0700
[ 24.804947] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 25.261000] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 31.441978] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 33.946640] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 35.601950] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E 1
[ 40.628774] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:1 02396k SSFS
[ 422.462597] usb 1-1.3: USB disconnect, device number 4
[ 422.540035] xc4000 1-0061: destroying instance
[ 422.541817] dvb-usb: Pinnacle PCTV Hybrid Stick Solo successfully deinitializ ed and disconnected.
[ 426.799446] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 426.900987] usb 1-1.3: New USB device found, idVendor=2304, idProduct=023e
[ 426.901020] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 426.901039] usb 1-1.3: Product: PCTV 340e SE
[ 426.901057] usb 1-1.3: Manufacturer: YUANRD
[ 426.901073] usb 1-1.3: SerialNumber: 0600F39CAF
[ 426.902838] dvb-usb: found a 'Pinnacle PCTV Hybrid Stick Solo' in cold state, will try to load a firmware
[ 426.904542] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[ 427.108304] dib0700: firmware started successfully.
[ 427.609478] dvb-usb: found a 'Pinnacle PCTV Hybrid Stick Solo' in warm state.
[ 427.610190] dvb-usb: will pass the complete MPEG2 transport stream to the sof tware demuxer.
[ 427.610459] DVB: registering new adapter (Pinnacle PCTV Hybrid Stick Solo)
[ 428.472743] usb 1-1.3: DVB: registering adapter 0 frontend 0 (DiBcom 7000PC). ..
[ 428.473546] xc4000 1-0061: creating new instance
[ 428.478955] xc4000: Successfully identified at address 0x61
[ 428.478974] xc4000: Firmware has not been loaded previously
[ 428.480742] Registered IR keymap rc-dib0700-rc5
[ 428.482386] input: IR-receiver inside an USB DVB receiver as /devices/platfor m/bcm2708_usb/usb1/1-1/1-1.3/rc/rc1/input1
[ 428.483068] rc1: IR-receiver inside an USB DVB receiver as /devices/platform/ bcm2708_usb/usb1/1-1/1-1.3/rc/rc1
[ 428.483352] dvb-usb: schedule remote query interval to 50 msecs.
[ 428.483381] dvb-usb: Pinnacle PCTV Hybrid Stick Solo successfully initialized and connected.
Dies ist die Ausgabe wenn TVheadend gestartet ist:
2014-01-02 17:22:18.655 [ INFO] charset: 138 entries loaded
2014-01-02 17:22:18.712 [ INFO] CSA: Using 32bit parallel descrambling
2014-01-02 17:22:18.715 [ INFO] epggrab: module eit created
2014-01-02 17:22:18.717 [ INFO] epggrab: module uk_freesat created
2014-01-02 17:22:18.720 [ INFO] epggrab: module uk_freeview created
2014-01-02 17:22:18.723 [ INFO] epggrab: module viasat_baltic created
2014-01-02 17:22:18.756 [ INFO] epggrab: module opentv-skyuk created
2014-01-02 17:22:18.758 [ INFO] epggrab: module opentv-skyit created
2014-01-02 17:22:18.761 [ INFO] epggrab: module opentv-ausat created
2014-01-02 17:22:18.771 [ INFO] epggrab: module pyepg created
2014-01-02 17:22:18.773 [ INFO] epggrab: module xmltv created
2014-01-02 17:22:18.789 [ INFO] dvr: Creating new configuration ''
2014-01-02 17:22:18.791 [WARNING] dvr: Output directory for video recording is not yet configured for DVR configuration "". Defaulting to to "/home/pi". This can be changed from the web user interface.
2014-01-02 17:22:18.809 [ NOTICE] START: HTS Tvheadend version 3.9.313~gf25d918 started, running as PID:2264 UID:1000 GID:1000, CWD:/usr/local/tvheadend/build.linux CNF:/home/pi/.hts/tvheadend
Ich hoffe mir kann jemand von euch helfen und ich möchte schon mal vorab ganz lieb Danke sagen
