- Offizieller Beitrag
Hei Leute,
habe vor ein 3x3x3 LED Cube zu basteln und wollte euch mal präsentieren, was ich bisher habe und woran es noch hapert.
Habe bisher diesen Schaltplan im Internet gefunden. Sowie folgenden Code:
#!/usr/bin/env/python3.2
# 3x3 LED Cube
# Position 11 - 33 are connected to LED Cathode (-)
# Layers are connected to LED Anode (+)
import RPi.GPIO as GPIO
from time import sleep
GPIO.setmode(GPIO.BOARD)
# Use physical pin numbering
GPIO.setup(7, GPIO.OUT) # Position 11
GPIO.setup(5, GPIO.OUT) # Position 12
GPIO.setup(3, GPIO.OUT) # Position 13
GPIO.setup(11, GPIO.OUT) # Position 21
GPIO.setup(13, GPIO.OUT) # Position 22
GPIO.setup(15, GPIO.OUT) # Position 23
GPIO.setup(19, GPIO.OUT) # Position 31
GPIO.setup(21, GPIO.OUT) # Position 32
GPIO.setup(23, GPIO.OUT) # Position 33
GPIO.setup(22, GPIO.OUT) # Position Top Layer
GPIO.setup(24, GPIO.OUT) # Position Middle Layer
GPIO.setup(26, GPIO.OUT) # Position Bottom Layer
delay = 0.05
def bottom():
GPIO.output(7, False)
GPIO.output(5, False)
GPIO.output(3, False)
GPIO.output(11, False)
GPIO.output(13, False)
GPIO.output(15, False)
GPIO.output(19, False)
GPIO.output(21, False)
GPIO.output(23, False)
GPIO.output(22, True)
GPIO.output(24, True)
GPIO.output(26, False)
def middle():
GPIO.output(24, False)
GPIO.output(26, True)
def top():
GPIO.output(22, False)
def allOff():
def layerOn():
GPIO.output(7, True)
GPIO.output(5, True)
GPIO.output(3, True)
GPIO.output(11, True)
GPIO.output(13, True)
GPIO.output(15, True)
GPIO.output(19, True)
GPIO.output(21, True)
GPIO.output(23, True)
# Main program
try:
print('Press CTRL+C to stop script')
i = 0
while(i < 3):
bottom()
sleep(delay)
sleep(delay)
sleep(delay)
middle()
sleep(delay)
sleep(delay)
sleep(delay)
top()
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
middle()
sleep(delay)
sleep(delay)
sleep(delay)
bottom()
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
middle()
sleep(delay)
sleep(delay)
sleep(delay)
top()
sleep(delay)
sleep(delay)
sleep(delay)
allOff()
i = i + 1
#sleep(1)
i = 0
while(i < 3):
bottom()
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
middle()
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
top()
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
middle()
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
i = i + 1
i = 0
while(i < 3):
bottom()
sleep(delay)
middle()
sleep(delay)
top()
sleep(delay)
sleep(delay)
sleep(delay)
sleep(delay)
middle()
sleep(delay)
sleep(delay)
bottom()
sleep(delay)
sleep(delay)
allOff()
i = i + 1
except KeyboardInterrupt:
GPIO.cleanup()
finally:
GPIO.cleanup()
Jedoch ist mir noch einiges unklar!
Ich benötige 27 Leds, sowie 27 Widerstände.
Bei 9 Säulen und 3 Ebenen brauchen wir also 12 Ausgänge am Pi, richtig?
- Habe diese LEDs im 100 Pack gefunden, gehen die?
- Welche Widerstände benötige ich?
- Ist es überhaupt möglich alle LEDs einzeln direkt an den Pi zu hängen,
ohne das dieser Schaden davon trägt?
- Ist der Code korrekt, bzw. die Pinbelegung? Das macht für mich bisher
leider wenig Sinn. Im Code steht Belegung nach Board. Also von 1 - 26
einfach durch? Weil im Schaltplan geht jeweils ein Anschluss auf jeder
Ebene weg (Minus), oder sehe ich das falsch? Und Plus bekommen die
LEDs durch die Säulen, richtig? Weil oben im Code sind Pin 22, 24 und
26 für die Ebenen angegeben. Aber im Schaltplan 7, 8, 25. Da komme
ich durcheinander.
Ich hoffe ihr könnt mir helfen. Werde, wenn ich selber erst mal alles verstanden habe und das Ding gebaut ist ein Tutorial in diesem Forum erstellen. Ist doch selbstverständlich
Also freue mich über jede Hilfe!!
