ich bräuchte mal bitte einen Denkanstoß.
Ich habe so ein günstiges NFC/RFID Modul [Anzeige] an einem Raspberry angeschlossen.
Funktioniert mit soweit alles gut.
Nun habe ich den Beispielcode speziel write.py angepasst um nicht nur in Sektor 8 zu schreiben.
Sieht jetzt wie folgt aus:
#!/usr/bin/env python
# -*- coding: utf8 -*-
import RPi.GPIO as GPIO
import MFRC522
import signal
def writeTag(p_data, p_nSector):
continue_reading = True
# Capture SIGINT for cleanup when the script is aborted
def end_read(signal,frame):
global continue_reading
print "Ctrl+C captured, ending read."
continue_reading = False
GPIO.cleanup()
# Hook the SIGINT
signal.signal(signal.SIGINT, end_read)
# Create an object of the class MFRC522
MIFAREReader = MFRC522.MFRC522()
# This loop keeps checking for chips. If one is near it will get the UID and authenticate
while continue_reading:
# Scan for cards
(status,TagType) = MIFAREReader.MFRC522_Request(MIFAREReader.PICC_REQIDL)
# If a card is found
if status == MIFAREReader.MI_OK:
print "Card detected"
# Get the UID of the card
(status,uid) = MIFAREReader.MFRC522_Anticoll()
# If we have the UID, continue
# Print UID
print "Card read UID: "+str(uid[0])+","+str(uid[1])+","+str(uid[2])+","+str(uid[3])
# This is the default key for authentication
key = [0xFF,0xFF,0xFF,0xFF,0xFF,0xFF]
# Select the scanned tag
MIFAREReader.MFRC522_SelectTag(uid)
# Authenticate
status = MIFAREReader.MFRC522_Auth(MIFAREReader.PICC_AUTHENT1A, p_nSector, key, uid)
print "\n"
# Check if authenticated
#Fill the data with 0xFF
for x in range(len(p_data),16):
p_data.append(0xFF)
# Write the data
MIFAREReader.MFRC522_Write(p_nSector, p_data)
print "\n"
# Stop
MIFAREReader.MFRC522_StopCrypto1()
# Make sure to stop reading for cards
else:
print "Authentication error"
#Main
data = [5,2,5,4,5,5,9,9,6,0,0,0,0]
writeTag(data, 1)
data = [5,2,5,4,5,5,0,0,5,0,0,0,0]
writeTag(data, 2)
data = [5,2,5,4,2,1,9,0,0,4,0,0,0]
writeTag(data, 3)
data = [5,2,5,4,3,5,8,0,8,0,0,0,0]
writeTag(data, 4)
Die verwendete Bibliothek sieht wie folgt aus:
import spi
import signal
import time
class MFRC522:
NRSTPD = 22
MAX_LEN = 16
PCD_IDLE = 0x00
PCD_AUTHENT = 0x0E
PCD_RECEIVE = 0x08
PCD_TRANSMIT = 0x04
PCD_TRANSCEIVE = 0x0C
PCD_RESETPHASE = 0x0F
PCD_CALCCRC = 0x03
PICC_REQIDL = 0x26
PICC_REQALL = 0x52
PICC_ANTICOLL = 0x93
PICC_SElECTTAG = 0x93
PICC_AUTHENT1A = 0x60
PICC_AUTHENT1B = 0x61
PICC_READ = 0x30
PICC_WRITE = 0xA0
PICC_DECREMENT = 0xC0
PICC_INCREMENT = 0xC1
PICC_RESTORE = 0xC2
PICC_TRANSFER = 0xB0
PICC_HALT = 0x50
MI_OK = 0
MI_NOTAGERR = 1
MI_ERR = 2
Reserved00 = 0x00
CommandReg = 0x01
CommIEnReg = 0x02
DivlEnReg = 0x03
CommIrqReg = 0x04
DivIrqReg = 0x05
ErrorReg = 0x06
Status1Reg = 0x07
Status2Reg = 0x08
FIFODataReg = 0x09
FIFOLevelReg = 0x0A
WaterLevelReg = 0x0B
ControlReg = 0x0C
BitFramingReg = 0x0D
CollReg = 0x0E
Reserved01 = 0x0F
Reserved10 = 0x10
ModeReg = 0x11
TxModeReg = 0x12
RxModeReg = 0x13
TxControlReg = 0x14
TxAutoReg = 0x15
TxSelReg = 0x16
RxSelReg = 0x17
RxThresholdReg = 0x18
DemodReg = 0x19
Reserved11 = 0x1A
Reserved12 = 0x1B
MifareReg = 0x1C
Reserved13 = 0x1D
Reserved14 = 0x1E
SerialSpeedReg = 0x1F
Reserved20 = 0x20
CRCResultRegM = 0x21
CRCResultRegL = 0x22
Reserved21 = 0x23
ModWidthReg = 0x24
Reserved22 = 0x25
RFCfgReg = 0x26
GsNReg = 0x27
CWGsPReg = 0x28
ModGsPReg = 0x29
TModeReg = 0x2A
TPrescalerReg = 0x2B
TReloadRegH = 0x2C
TReloadRegL = 0x2D
TCounterValueRegH = 0x2E
TCounterValueRegL = 0x2F
Reserved30 = 0x30
TestSel1Reg = 0x31
TestSel2Reg = 0x32
TestPinEnReg = 0x33
TestPinValueReg = 0x34
TestBusReg = 0x35
AutoTestReg = 0x36
VersionReg = 0x37
AnalogTestReg = 0x38
TestDAC1Reg = 0x39
TestDAC2Reg = 0x3A
TestADCReg = 0x3B
Reserved31 = 0x3C
Reserved32 = 0x3D
Reserved33 = 0x3E
Reserved34 = 0x3F
serNum = []
def __init__(self, dev='/dev/spidev0.0', spd=1000000):
spi.openSPI(device=dev,speed=spd)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(22, GPIO.OUT)
GPIO.output(self.NRSTPD, 1)
self.MFRC522_Init()
def MFRC522_Reset(self):
self.Write_MFRC522(self.CommandReg, self.PCD_RESETPHASE)
def Write_MFRC522(self, addr, val):
spi.transfer(((addr<<1)&0x7E,val))
def Read_MFRC522(self, addr):
val = spi.transfer((((addr<<1)&0x7E) | 0x80,0))
return val[1]
def SetBitMask(self, reg, mask):
tmp = self.Read_MFRC522(reg)
self.Write_MFRC522(reg, tmp | mask)
def ClearBitMask(self, reg, mask):
tmp = self.Read_MFRC522(reg);
self.Write_MFRC522(reg, tmp & (~mask))
def AntennaOn(self):
temp = self.Read_MFRC522(self.TxControlReg)
if(~(temp & 0x03)):
self.SetBitMask(self.TxControlReg, 0x03)
def AntennaOff(self):
self.ClearBitMask(self.TxControlReg, 0x03)
def MFRC522_ToCard(self,command,sendData):
backData = []
backLen = 0
status = self.MI_ERR
irqEn = 0x00
waitIRq = 0x00
lastBits = None
n = 0
i = 0
if command == self.PCD_AUTHENT:
irqEn = 0x12
waitIRq = 0x10
if command == self.PCD_TRANSCEIVE:
irqEn = 0x77
waitIRq = 0x30
self.Write_MFRC522(self.CommIEnReg, irqEn|0x80)
self.ClearBitMask(self.CommIrqReg, 0x80)
self.SetBitMask(self.FIFOLevelReg, 0x80)
self.Write_MFRC522(self.CommandReg, self.PCD_IDLE);
while(i<len(sendData)):
self.Write_MFRC522(self.FIFODataReg, sendData[i])
i = i+1
self.Write_MFRC522(self.CommandReg, command)
self.SetBitMask(self.BitFramingReg, 0x80)
i = 2000
while True:
n = self.Read_MFRC522(self.CommIrqReg)
i = i - 1
if ~((i!=0) and ~(n&0x01) and ~(n&waitIRq)):
break
self.ClearBitMask(self.BitFramingReg, 0x80)
if i != 0:
if (self.Read_MFRC522(self.ErrorReg) & 0x1B)==0x00:
status = self.MI_OK
if n & irqEn & 0x01:
status = self.MI_NOTAGERR
n = self.Read_MFRC522(self.FIFOLevelReg)
lastBits = self.Read_MFRC522(self.ControlReg) & 0x07
if lastBits != 0:
backLen = (n-1)*8 + lastBits
else:
backLen = n*8
if n == 0:
n = 1
if n > self.MAX_LEN:
n = self.MAX_LEN
i = 0
while i<n:
backData.append(self.Read_MFRC522(self.FIFODataReg))
i = i + 1;
else:
return (status,backData,backLen)
def MFRC522_Request(self, reqMode):
status = None
backBits = None
TagType = []
self.Write_MFRC522(self.BitFramingReg, 0x07)
TagType.append(reqMode);
(status,backData,backBits) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, TagType)
if ((status != self.MI_OK) | (backBits != 0x10)):
return (status,backBits)
def MFRC522_Anticoll(self):
backData = []
serNumCheck = 0
serNum = []
self.Write_MFRC522(self.BitFramingReg, 0x00)
serNum.append(self.PICC_ANTICOLL)
serNum.append(0x20)
(status,backData,backBits) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE,serNum)
if(status == self.MI_OK):
i = 0
if len(backData)==5:
while i<4:
serNumCheck = serNumCheck ^ backData[i]
i = i + 1
if serNumCheck != backData[i]:
else:
return (status,backData)
def CalulateCRC(self, pIndata):
self.ClearBitMask(self.DivIrqReg, 0x04)
self.SetBitMask(self.FIFOLevelReg, 0x80);
i = 0
while i<len(pIndata):
self.Write_MFRC522(self.FIFODataReg, pIndata[i])
i = i + 1
self.Write_MFRC522(self.CommandReg, self.PCD_CALCCRC)
i = 0xFF
while True:
n = self.Read_MFRC522(self.DivIrqReg)
i = i - 1
if not ((i != 0) and not (n&0x04)):
break
pOutData = []
pOutData.append(self.Read_MFRC522(self.CRCResultRegL))
pOutData.append(self.Read_MFRC522(self.CRCResultRegM))
return pOutData
def MFRC522_SelectTag(self, serNum):
backData = []
buf = []
buf.append(self.PICC_SElECTTAG)
buf.append(0x70)
i = 0
while i<5:
buf.append(serNum[i])
i = i + 1
pOut = self.CalulateCRC(buf)
buf.append(pOut[0])
buf.append(pOut[1])
(status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, buf)
if (status == self.MI_OK) and (backLen == 0x18):
print "Size: " + str(backData[0])
return backData[0]
else:
return 0
def MFRC522_Auth(self, authMode, BlockAddr, Sectorkey, serNum):
buff = []
# First byte should be the authMode (A or B)
buff.append(authMode)
# Second byte is the trailerBlock (usually 7)
buff.append(BlockAddr)
# Now we need to append the authKey which usually is 6 bytes of 0xFF
i = 0
while(i < len(Sectorkey)):
buff.append(Sectorkey[i])
i = i + 1
i = 0
# Next we append the first 4 bytes of the UID
while(i < 4):
buff.append(serNum[i])
i = i +1
# Now we start the authentication itself
(status, backData, backLen) = self.MFRC522_ToCard(self.PCD_AUTHENT,buff)
# Check if an error occurred
if not(status == self.MI_OK):
print "AUTH ERROR!!"
if not (self.Read_MFRC522(self.Status2Reg) & 0x08) != 0:
print "AUTH ERROR(status2reg & 0x08) != 0"
# Return the status
return status
def MFRC522_StopCrypto1(self):
self.ClearBitMask(self.Status2Reg, 0x08)
def MFRC522_Read(self, blockAddr):
recvData = []
recvData.append(self.PICC_READ)
recvData.append(blockAddr)
pOut = self.CalulateCRC(recvData)
recvData.append(pOut[0])
recvData.append(pOut[1])
(status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, recvData)
print "Error while reading!"
i = 0
if len(backData) == 16:
print "Sector "+str(blockAddr)+" "+str(backData)
def MFRC522_Write(self, blockAddr, writeData):
buff = []
buff.append(self.PICC_WRITE)
buff.append(blockAddr)
crc = self.CalulateCRC(buff)
buff.append(crc[0])
buff.append(crc[1])
(status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, buff)
if not(status == self.MI_OK) or not(backLen == 4) or not((backData[0] & 0x0F) == 0x0A):
print str(backLen)+" backdata &0x0F == 0x0A "+str(backData[0]&0x0F)
if status == self.MI_OK:
i = 0
buf = []
while i < 16:
buf.append(writeData[i])
i = i + 1
crc = self.CalulateCRC(buf)
buf.append(crc[0])
buf.append(crc[1])
(status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE,buf)
print "Error while writing"
print "Data written"
def MFRC522_DumpClassic1K(self, key, uid):
i = 0
while i < 64:
status = self.MFRC522_Auth(self.PICC_AUTHENT1A, i, key, uid)
self.MFRC522_Read(i)
else:
i = i+1
def MFRC522_Init(self):
self.MFRC522_Reset();
self.Write_MFRC522(self.TModeReg, 0x8D)
self.Write_MFRC522(self.TPrescalerReg, 0x3E)
self.Write_MFRC522(self.TReloadRegL, 30)
self.Write_MFRC522(self.TReloadRegH, 0)
self.Write_MFRC522(self.TxAutoReg, 0x40)
self.Write_MFRC522(self.ModeReg, 0x3D)
self.AntennaOn()
Mein Problem:
Ich bekomme jetzt nach dem Schreiben die Fehlermeldung "AUTH ERROR", "AUTH ERROR(status2reg & 0x08) != 0"
wenn ich die Sektoren 1,2 und 3 lesen oder schreiben möchte.
Sektor 4 kann ich problemlos lesen und schreiben.
Hab ich ins Status Register geschrieben oder was ist mein Fehler?
Ich habe das gleiche Spiel mit anderen Sektoren probiert und habe einen ähnlichen Effekt nur mit anderen Sektoren (1 bis 5 les- und schreibbar 6 bis 9 nicht und ab 10 wieder schreib- und lesbar).
Kann mir jemand einen Tipp geben?
