ich habe folgendes LCD Display: http://www.aliexpress.com/item/Tontec-7-…2342066895.html
Die Auflösung ist 800x480
Ich hatte das Display an meinem Pi 2 B sowie an meinem Pi B schon aktiv, leider habe ich dann meine SD Karte zerstört. jetzt bekomme ich kein Bild mehr...
Das Display zeigt nur noch schwarz, nicht aber "kein Signal" - es wird also erkannt, dass was eingesteckt ist.
An einem normalen PC Monitor funktioniert die Bildausgabe einwandfrei.
So sieht meine Config.txt aus:
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=800
framebuffer_height=480
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=2
#hdmi_mode=9
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=1
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
sdtv_aspect=3
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=i2c_arm=on
#device_tree=bcm2708-rpi-b.dtb
device_tree_param=i2c=on1=on
device_tree_param=spi=on
ich habe schon versucht mit den verschiedenen Werten von "hdmi_group", "hdmi_mode", "sdtv_mode", "sdtv_aspect", "hdmi_drive" versucht rum zu spielen... bisher leider ohne erfolg!
auch "hdmi_save" bringt nichts..
Hat jemand ideen oder vorschläge was ich noch ausprobieren könnte?
Viele Grüße
