habe nun seit gestern mein Raspberry Pi und habe dort auch schon einen Webserver etc installiert. Anfangs habe ich eine bestimmte IP über die interfaces-Datei (in /etc/network...) festgelegt. Diese möchte ich jetzt aber ändern. Das funktioniert jedoch nicht, die IP will sich einfach nicht ändern.
So sieht die interfaces-Datei aus:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
und so sieht die dhcpcd.conf-Datei aus:
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
static ip_adress=***.***.*.*/24
static routers=***.***.*.*
static domain_name_servers=***.***.*.*
Die IPs, die ich jetzt hier durch Sternchen ersetzt habe, stimmen alle. Die habe ich mehrmals überprüft. Habe ich sonst irgendetwas falsch eingestellt? Habe das Gerät mehrmals neugestartet.
Wenn ihr weitere Infos braucht, sagt Bescheid. Weiß leider noch nicht was alles für's Troubleshooting relevant ist.
Grüße,
Janglx
