Hallo Forum, ich habe an meinem Model B einen Ralink RT5370 Stick angeschlossen. Obwohl meine "/etc/network/interfaces" so aussieht:
ZitatAlles anzeigen
auto loiface lo inet loopback
iface eth0 inet dhcpauto wlan0
#allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
startet der Stick erste wenn ich folgende Befehle an der EIngabemaske eingebe
sudo wpa_action wlan0 stop
sudo ifup wlan0
Was mache ich falsch bzw. warum startet das Netzwerk nicht richtig
Folgendes steht im Log:
Oct 13 16:30:16 raspberrypi kernel: [ 2.164996] usbcore: registered new interface driver usbhid
Oct 13 16:30:16 raspberrypi kernel: [ 2.172091] usbhid: USB HID core driver
Oct 13 16:30:16 raspberrypi kernel: [ 2.181961] TCP: cubic registered
Oct 13 16:30:16 raspberrypi kernel: [ 2.188750] Initializing XFRM netlink socket
Oct 13 16:30:16 raspberrypi kernel: [ 2.196493] NET: Registered protocol family 17
Oct 13 16:30:16 raspberrypi kernel: [ 2.202499] Key type dns_resolver registered
Oct 13 16:30:16 raspberrypi kernel: [ 2.211570] Indeed it is in host mode hprt0 = 00021501
Oct 13 16:30:16 raspberrypi kernel: [ 2.222504] registered taskstats version 1
Oct 13 16:30:16 raspberrypi kernel: [ 2.237166] Waiting for root device /dev/mmcblk0p2...
Oct 13 16:30:16 raspberrypi kernel: [ 2.267219] mmc0: new high speed SDHC card at address 0002
Oct 13 16:30:16 raspberrypi kernel: [ 2.286161] mmcblk0: mmc0:0002 00000 7.32 GiB
Oct 13 16:30:16 raspberrypi kernel: [ 2.296972] mmcblk0: p1 p2
Oct 13 16:30:16 raspberrypi kernel: [ 2.361921] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Oct 13 16:30:16 raspberrypi kernel: [ 2.373222] VFS: Mounted root (ext4 filesystem) on device 179:2.
Oct 13 16:30:16 raspberrypi kernel: [ 2.381941] devtmpfs: mounted
Oct 13 16:30:16 raspberrypi kernel: [ 2.386945] Freeing unused kernel memory: 140K (c05bd000 - c05e0000)
Oct 13 16:30:16 raspberrypi kernel: [ 2.426058] usb 1-1: new high-speed USB device number 2 using dwc_otg
Oct 13 16:30:16 raspberrypi kernel: [ 2.434762] Indeed it is in host mode hprt0 = 00001101
Oct 13 16:30:16 raspberrypi kernel: [ 2.646410] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Oct 13 16:30:16 raspberrypi kernel: [ 2.654678] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Oct 13 16:30:16 raspberrypi kernel: [ 2.667145] hub 1-1:1.0: USB hub found
Oct 13 16:30:16 raspberrypi kernel: [ 2.673494] hub 1-1:1.0: 5 ports detected
Oct 13 16:30:16 raspberrypi kernel: [ 2.956188] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Oct 13 16:30:16 raspberrypi kernel: [ 3.066516] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Oct 13 16:30:16 raspberrypi kernel: [ 3.075012] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Oct 13 16:30:16 raspberrypi kernel: [ 3.097014] smsc95xx v1.0.4
Oct 13 16:30:16 raspberrypi kernel: [ 3.171151] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a6:03:f9
Oct 13 16:30:16 raspberrypi kernel: [ 3.286135] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Oct 13 16:30:16 raspberrypi kernel: [ 3.414023] usb 1-1.2: New USB device found, idVendor=148f, idProduct=3070
Oct 13 16:30:16 raspberrypi kernel: [ 3.432079] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 13 16:30:16 raspberrypi kernel: [ 3.452511] usb 1-1.2: Product: 802.11 n WLAN
Oct 13 16:30:16 raspberrypi kernel: [ 3.466061] usb 1-1.2: Manufacturer: Ralink
Oct 13 16:30:16 raspberrypi kernel: [ 3.471835] usb 1-1.2: SerialNumber: 1.0
Oct 13 16:30:16 raspberrypi kernel: [ 3.566218] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
Oct 13 16:30:16 raspberrypi kernel: [ 3.714245] usb 1-1.3: New USB device found, idVendor=148f, idProduct=5370
Oct 13 16:30:16 raspberrypi kernel: [ 3.729786] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 13 16:30:16 raspberrypi kernel: [ 3.739028] usb 1-1.3: Product: 802.11 n WLAN
Oct 13 16:30:16 raspberrypi kernel: [ 3.744877] usb 1-1.3: Manufacturer: Ralink
Oct 13 16:30:16 raspberrypi kernel: [ 3.750562] usb 1-1.3: SerialNumber: 1.0
Oct 13 16:30:16 raspberrypi kernel: [ 5.593691] cfg80211: Calling CRDA to update world regulatory domain
Oct 13 16:30:16 raspberrypi kernel: [ 6.066206] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
Oct 13 16:30:16 raspberrypi kernel: [ 6.264641] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
Oct 13 16:30:16 raspberrypi kernel: [ 6.357052] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 3070, rev 0201 detected
Oct 13 16:30:16 raspberrypi kernel: [ 6.937579] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected
Oct 13 16:30:16 raspberrypi kernel: [ 7.196278] usb 1-1.3: reset high-speed USB device number 5 using dwc_otg
Oct 13 16:30:16 raspberrypi kernel: [ 7.369801] ieee80211 phy1: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
Oct 13 16:30:16 raspberrypi kernel: [ 7.533926] ieee80211 phy1: rt2x00_set_rf: Info - RF chipset 5370 detected
Oct 13 16:30:16 raspberrypi kernel: [ 7.550425] usbcore: registered new interface driver rt2800usb
Oct 13 16:30:16 raspberrypi kernel: [ 10.806933] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Oct 13 16:30:16 raspberrypi kernel: [ 11.324204] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Oct 13 16:30:16 raspberrypi kernel: [ 20.384503] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
Oct 13 16:30:16 raspberrypi kernel: [ 20.397528] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
Oct 13 16:30:16 raspberrypi kernel: [ 21.166753] ieee80211 phy1: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
Oct 13 16:30:16 raspberrypi kernel: [ 21.166802] ieee80211 phy1: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
Oct 13 16:30:16 raspberrypi kernel: [ 21.590914] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Oct 13 16:30:16 raspberrypi kernel: [ 23.108735] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
Oct 13 16:30:18 raspberrypi kernel: [ 29.884462] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
Oct 13 16:33:14 raspberrypi kernel: [ 179.332956] wlan0: authenticate with 01:02:03:ab:cd:ef
Oct 13 16:33:15 raspberrypi kernel: [ 179.402960] wlan0: send auth to 01:02:03:ab:cd:ef (try 1/3)
Oct 13 16:33:15 raspberrypi kernel: [ 179.404636] wlan0: authenticated
Oct 13 16:33:15 raspberrypi kernel: [ 179.416023] wlan0: associate with 01:02:03:ab:cd:ef (try 1/3)
Oct 13 16:33:15 raspberrypi kernel: [ 179.418736] wlan0: RX AssocResp from 01:02:03:ab:cd:ef (capab=0x431 status=0 aid=4)
Oct 13 16:33:15 raspberrypi kernel: [ 179.431057] wlan0: associated
Oct 13 16:33:15 raspberrypi wpa_action: WPA_IFACE=wlan0 WPA_ACTION=CONNECTED
Oct 13 16:33:15 raspberrypi wpa_action: WPA_ID=1 WPA_ID_STR=zuhause WPA_CTRL_DIR=/var/run/wpa_supplicant
Oct 13 16:33:15 raspberrypi wpa_action: network settings not defined for zuhause in /etc/network/interfaces
Oct 13 16:33:15 raspberrypi wpa_action: ifup wlan0=default
Oct 13 16:33:22 raspberrypi wpa_action: creating sendsigs omission pidfile: /run/sendsigs.omit.d/wpasupplicant.wpa_supplicant.wlan0.pid
Oct 13 16:33:22 raspberrypi wpa_action: bssid=f4:ec:38:b4:d6:2d
Oct 13 16:33:22 raspberrypi wpa_action: ssid=kein_eingang
Oct 13 16:33:22 raspberrypi wpa_action: id=1
Oct 13 16:33:22 raspberrypi wpa_action: id_str=zuhause
Oct 13 16:33:22 raspberrypi wpa_action: mode=station
Oct 13 16:33:22 raspberrypi wpa_action: pairwise_cipher=CCMP
Oct 13 16:33:22 raspberrypi wpa_action: group_cipher=CCMP
Oct 13 16:33:22 raspberrypi wpa_action: key_mgmt=WPA2-PSK
Oct 13 16:33:22 raspberrypi wpa_action: wpa_state=COMPLETED
Oct 13 16:33:22 raspberrypi wpa_action: ip_address=10.1.1.193
Oct 13 16:33:22 raspberrypi wpa_action: address=ab:cd:ef:01:02:03
