Hi Leute,
und zwar habe ich jetzt schon viel ausprobiert und experimentiert und das Image 100 mal neu aufgesetzt.
Auch habe ich mit Joern von http://www.retro-programming.de/ geredet. Auch er weiß nicht mehr weiter.
Es geht um die Funktion, die Geschwindigleit im Spiel zu erhöhen in der RetroPie- EmulationStation 2 (Image 2.3, PI Version Model B - rev. 2). Leider ist das die einzige Funktion die nicht funktioniert. Weder mit Tastatur, noch mit SNES- oder XBOX360- Controller.
core_options_path = "/opt/retropie/configs/all/retroarch-core-options.cfg"
system_directory = "~/RetroPie/roms/../BIOS"
config_save_on_exit = "true"
video_threaded = "true"
video_smooth = "false"
video_aspect_ratio = "1.330000"
video_shader_dir = "/opt/retropie/emulators/RetroArch/shader/"
input_autodetect_enable = "true"
joypad_autoconfig_dir = "/opt/retropie/emulators/RetroArch/configs/"
input_debug_enable = "true"
input_player1_a = "x"
input_player1_b = "z"
input_player1_y = "a"
input_player1_x = "s"
input_player1_start = "enter"
input_player1_select = "rshift"
input_player1_l = "q"
input_player1_r = "w"
input_player1_left = "left"
input_player1_right = "right"
input_player1_up = "up"
input_player1_down = "down"
input_player1_turbo = "nul"
input_turbo_period = "6"
input_turbo_duty_cycle = "3"
input_exit_emulator = "escape"
input_shader_next = "m"
input_shader_prev = "n"
input_rewind = "r"
input_menu_toggle = "f1"
rewind_enable = "true"
rewind_buffer_size = "10"
rewind_granularity = "1"
video_gpu_screenshot = "true"
fastforward_ratio = "-1.000000"
slowmotion_ratio = "3.000000"
input_axis_threshold = "0.500000"
load_dummy_on_core_shutdown = "true"
fps_show = "true"
libretro_path = "/opt/retropie/emulatorcores/pocketsnes-libretro/libretro.so"
audio_latency = "64"
audio_sync = "true"
audio_block_frames = "0"
video_shader = "/opt/retropie/emulators/RetroArch/shader/snes_phosphor.glslp"
video_shader_enable = "false"
video_windowed_fullscreen = "true"
video_xscale = "3.000000"
autosave_interval = "0"
video_yscale = "3.000000"
video_crop_overscan = "true"
video_scale_integer = "false"
video_shared_context = "false"
video_fullscreen = "false"
video_refresh_rate = "59.950001"
video_monitor_index = "0"
video_fullscreen_x = "0"
video_fullscreen_y = "0"
video_driver = "gl"
menu_driver = "rgui"
video_vsync = "true"
video_hard_sync = "false"
video_hard_sync_frames = "0"
video_black_frame_insertion = "false"
video_disable_composition = "false"
pause_nonactive = "false"
video_swap_interval = "1"
video_rotation = "0"
screenshot_directory = "default"
aspect_ratio_index = "4"
audio_rate_control = "true"
audio_rate_control_delta = "0.005000"
audio_driver = "alsathread"
audio_out_rate = "48000"
video_font_size = "32.000000"
video_font_enable = "true"
audio_resampler = "sinc"
savefile_directory = "default"
savestate_directory = "default"
video_filter_dir = "default"
audio_filter_dir = "default"
content_directory = "default"
assets_directory = "default"
rgui_browser_directory = "default"
rgui_config_directory = "default"
rgui_show_start_screen = "false"
game_history_size = "100"
overlay_directory = "default"
input_overlay_enable = "false"
input_overlay_opacity = "0.700000"
input_overlay_scale = "1.000000"
gamma_correction = "false"
triple_buffering_enable = "false"
soft_filter_enable = "false"
flicker_filter_enable = "false"
flicker_filter_index = "0"
soft_filter_index = "0"
current_resolution_id = "0"
custom_viewport_width = "1021"
custom_viewport_height = "768"
custom_viewport_x = "1"
custom_viewport_y = "0"
block_sram_overwrite = "false"
savestate_auto_index = "false"
savestate_auto_save = "false"
savestate_auto_load = "true"
sound_mode = "0"
state_slot = "1"
netplay_spectator_mode_enable = "false"
netplay_mode = "false"
netplay_ip_port = "0"
netplay_delay_frames = "0"
custom_bgm_enable = "false"
input_driver = "udev"
input_device_p1 = "0"
input_player1_joypad_index = "0"
input_libretro_device_p1 = "1"
input_player1_analog_dpad_mode = "0"
input_device_p2 = "0"
input_player2_joypad_index = "1"
input_libretro_device_p2 = "1"
input_player2_analog_dpad_mode = "0"
input_device_p3 = "0"
input_player3_joypad_index = "2"
input_libretro_device_p3 = "1"
input_player3_analog_dpad_mode = "0"
input_device_p4 = "0"
input_player4_joypad_index = "3"
input_libretro_device_p4 = "1"
input_player4_analog_dpad_mode = "0"
input_device_p5 = "0"
input_player5_joypad_index = "4"
input_libretro_device_p5 = "1"
input_player5_analog_dpad_mode = "0"
input_device_p6 = "0"
input_player6_joypad_index = "5"
input_libretro_device_p6 = "1"
input_player6_analog_dpad_mode = "0"
input_device_p7 = "0"
input_player7_joypad_index = "6"
input_libretro_device_p7 = "1"
input_player7_analog_dpad_mode = "0"
input_device_p8 = "0"
input_player8_joypad_index = "7"
input_libretro_device_p8 = "1"
input_player8_analog_dpad_mode = "0"
input_player1_b_btn = "nul"
input_player1_b_axis = "nul"
input_player1_y_btn = "nul"
input_player1_y_axis = "nul"
input_player1_select_btn = "nul"
input_player1_select_axis = "nul"
input_player1_start_btn = "nul"
input_player1_start_axis = "nul"
input_player1_up_btn = "nul"
input_player1_up_axis = "nul"
input_player1_down_btn = "nul"
input_player1_down_axis = "nul"
input_player1_left_btn = "nul"
input_player1_left_axis = "nul"
input_player1_right_btn = "nul"
input_player1_right_axis = "nul"
input_player1_a_btn = "nul"
input_player1_a_axis = "nul"
input_player1_x_btn = "nul"
input_player1_x_axis = "nul"
input_player1_l_btn = "nul"
input_player1_l_axis = "nul"
input_player1_r_btn = "nul"
input_player1_r_axis = "nul"
input_player1_l2 = "nul"
input_player1_l2_btn = "nul"
input_player1_l2_axis = "nul"
input_player1_r2 = "nul"
input_player1_r2_btn = "nul"
input_player1_r2_axis = "nul"
input_player1_l3 = "nul"
input_player1_l3_btn = "nul"
input_player1_l3_axis = "nul"
input_player1_r3 = "nul"
input_player1_r3_btn = "nul"
input_player1_r3_axis = "nul"
input_player1_l_x_plus = "nul"
input_player1_l_x_plus_btn = "nul"
input_player1_l_x_plus_axis = "nul"
input_player1_l_x_minus = "nul"
input_player1_l_x_minus_btn = "nul"
input_player1_l_x_minus_axis = "nul"
input_player1_l_y_plus = "nul"
input_player1_l_y_plus_btn = "nul"
input_player1_l_y_plus_axis = "nul"
input_player1_l_y_minus = "nul"
input_player1_l_y_minus_btn = "nul"
input_player1_l_y_minus_axis = "nul"
input_player1_r_x_plus = "nul"
input_player1_r_x_plus_btn = "nul"
input_player1_r_x_plus_axis = "nul"
input_player1_r_x_minus = "nul"
input_player1_r_x_minus_btn = "nul"
input_player1_r_x_minus_axis = "nul"
input_player1_r_y_plus = "nul"
input_player1_r_y_plus_btn = "nul"
input_player1_r_y_plus_axis = "nul"
input_player1_r_y_minus = "nul"
input_player1_r_y_minus_btn = "nul"
input_player1_r_y_minus_axis = "nul"
input_player1_turbo_btn = "6"
input_player1_turbo_axis = "nul"
input_toggle_fast_forward = "space"
input_toggle_fast_forward_btn = "0"
input_toggle_fast_forward_axis = "nul"
input_hold_fast_forward = "l"
input_hold_fast_forward_btn = "0"
input_hold_fast_forward_axis = "nul"
input_load_state = "f4"
input_load_state_btn = "nul"
input_load_state_axis = "nul"
input_save_state = "f2"
input_save_state_btn = "nul"
input_save_state_axis = "nul"
input_toggle_fullscreen = "f"
input_toggle_fullscreen_btn = "nul"
input_toggle_fullscreen_axis = "nul"
input_exit_emulator_btn = "8"
input_exit_emulator_axis = "nul"
input_state_slot_increase = "f7"
input_state_slot_increase_btn = "nul"
input_state_slot_increase_axis = "nul"
input_state_slot_decrease = "f6"
input_state_slot_decrease_btn = "nul"
input_state_slot_decrease_axis = "nul"
input_rewind_btn = "h0down"
input_rewind_axis = "nul"
input_movie_record_toggle = "o"
input_movie_record_toggle_btn = "nul"
input_movie_record_toggle_axis = "nul"
input_pause_toggle = "p"
input_pause_toggle_btn = "nul"
input_pause_toggle_axis = "nul"
input_frame_advance = "k"
input_frame_advance_btn = "nul"
input_frame_advance_axis = "nul"
input_reset = "h"
input_reset_btn = "nul"
input_reset_axis = "nul"
input_shader_next_btn = "nul"
input_shader_next_axis = "nul"
input_shader_prev_btn = "nul"
input_shader_prev_axis = "nul"
input_cheat_index_plus = "y"
input_cheat_index_plus_btn = "nul"
input_cheat_index_plus_axis = "nul"
input_cheat_index_minus = "t"
input_cheat_index_minus_btn = "nul"
input_cheat_index_minus_axis = "nul"
input_cheat_toggle = "u"
input_cheat_toggle_btn = "nul"
input_cheat_toggle_axis = "nul"
input_screenshot = "f8"
input_screenshot_btn = "nul"
input_screenshot_axis = "nul"
input_audio_mute = "f9"
input_audio_mute_btn = "nul"
input_audio_mute_axis = "nul"
input_netplay_flip_players = "i"
input_netplay_flip_players_btn = "nul"
input_netplay_flip_players_axis = "nul"
input_slowmotion = "e"
input_slowmotion_btn = "h0left"
input_slowmotion_axis = "nul"
input_enable_hotkey = "nul"
input_enable_hotkey_btn = "10"
input_enable_hotkey_axis = "nul"
input_volume_up = "add"
input_volume_up_btn = "nul"
input_volume_up_axis = "nul"
input_volume_down = "subtract"
input_volume_down_btn = "nul"
input_volume_down_axis = "nul"
input_overlay_next = "nul"
input_overlay_next_btn = "nul"
input_overlay_next_axis = "nul"
input_disk_eject_toggle = "nul"
input_disk_eject_toggle_btn = "nul"
input_disk_eject_toggle_axis = "nul"
input_disk_next = "nul"
input_disk_next_btn = "nul"
input_disk_next_axis = "nul"
input_grab_mouse_toggle = "f11"
input_grab_mouse_toggle_btn = "nul"
input_grab_mouse_toggle_axis = "nul"
input_menu_toggle_btn = "5"
input_menu_toggle_axis = "nul"
input_player2_b = "nul"
input_player2_b_btn = "nul"
input_player2_b_axis = "nul"
input_player2_y = "nul"
input_player2_y_btn = "nul"
input_player2_y_axis = "nul"
input_player2_select = "nul"
input_player2_select_btn = "nul"
input_player2_select_axis = "nul"
input_player2_start = "nul"
input_player2_start_btn = "nul"
input_player2_start_axis = "nul"
input_player2_up = "nul"
input_player2_up_btn = "nul"
input_player2_up_axis = "nul"
input_player2_down = "nul"
input_player2_down_btn = "nul"
input_player2_down_axis = "nul"
input_player2_left = "nul"
input_player2_left_btn = "nul"
input_player2_left_axis = "nul"
input_player2_right = "nul"
input_player2_right_btn = "nul"
input_player2_right_axis = "nul"
input_player2_a = "nul"
input_player2_a_btn = "nul"
input_player2_a_axis = "nul"
input_player2_x = "nul"
input_player2_x_btn = "nul"
input_player2_x_axis = "nul"
input_player2_l = "nul"
input_player2_l_btn = "nul"
input_player2_l_axis = "nul"
input_player2_r = "nul"
input_player2_r_btn = "nul"
input_player2_r_axis = "nul"
input_player2_l2 = "nul"
input_player2_l2_btn = "nul"
input_player2_l2_axis = "nul"
input_player2_r2 = "nul"
input_player2_r2_btn = "nul"
input_player2_r2_axis = "nul"
input_player2_l3 = "nul"
input_player2_l3_btn = "nul"
input_player2_l3_axis = "nul"
input_player2_r3 = "nul"
input_player2_r3_btn = "nul"
input_player2_r3_axis = "nul"
input_player2_l_x_plus = "nul"
input_player2_l_x_plus_btn = "nul"
input_player2_l_x_plus_axis = "nul"
input_player2_l_x_minus = "nul"
input_player2_l_x_minus_btn = "nul"
input_player2_l_x_minus_axis = "nul"
input_player2_l_y_plus = "nul"
input_player2_l_y_plus_btn = "nul"
input_player2_l_y_plus_axis = "nul"
input_player2_l_y_minus = "nul"
input_player2_l_y_minus_btn = "nul"
input_player2_l_y_minus_axis = "nul"
input_player2_r_x_plus = "nul"
input_player2_r_x_plus_btn = "nul"
input_player2_r_x_plus_axis = "nul"
input_player2_r_x_minus = "nul"
input_player2_r_x_minus_btn = "nul"
input_player2_r_x_minus_axis = "nul"
input_player2_r_y_plus = "nul"
input_player2_r_y_plus_btn = "nul"
input_player2_r_y_plus_axis = "nul"
input_player2_r_y_minus = "nul"
input_player2_r_y_minus_btn = "nul"
input_player2_r_y_minus_axis = "nul"
input_player2_turbo = "nul"
input_player2_turbo_btn = "nul"
input_player2_turbo_axis = "nul"
input_player3_b = "nul"
input_player3_b_btn = "nul"
input_player3_b_axis = "nul"
input_player3_y = "nul"
input_player3_y_btn = "nul"
input_player3_y_axis = "nul"
input_player3_select = "nul"
input_player3_select_btn = "nul"
input_player3_select_axis = "nul"
input_player3_start = "nul"
input_player3_start_btn = "nul"
input_player3_start_axis = "nul"
input_player3_up = "nul"
input_player3_up_btn = "nul"
input_player3_up_axis = "nul"
input_player3_down = "nul"
input_player3_down_btn = "nul"
input_player3_down_axis = "nul"
input_player3_left = "nul"
input_player3_left_btn = "nul"
input_player3_left_axis = "nul"
input_player3_right = "nul"
input_player3_right_btn = "nul"
input_player3_right_axis = "nul"
input_player3_a = "nul"
input_player3_a_btn = "nul"
input_player3_a_axis = "nul"
input_player3_x = "nul"
input_player3_x_btn = "nul"
input_player3_x_axis = "nul"
input_player3_l = "nul"
input_player3_l_btn = "nul"
input_player3_l_axis = "nul"
input_player3_r = "nul"
input_player3_r_btn = "nul"
input_player3_r_axis = "nul"
input_player3_l2 = "nul"
input_player3_l2_btn = "nul"
input_player3_l2_axis = "nul"
input_player3_r2 = "nul"
input_player3_r2_btn = "nul"
input_player3_r2_axis = "nul"
input_player3_l3 = "nul"
input_player3_l3_btn = "nul"
input_player3_l3_axis = "nul"
input_player3_r3 = "nul"
input_player3_r3_btn = "nul"
input_player3_r3_axis = "nul"
input_player3_l_x_plus = "nul"
input_player3_l_x_plus_btn = "nul"
input_player3_l_x_plus_axis = "nul"
input_player3_l_x_minus = "nul"
input_player3_l_x_minus_btn = "nul"
input_player3_l_x_minus_axis = "nul"
input_player3_l_y_plus = "nul"
input_player3_l_y_plus_btn = "nul"
input_player3_l_y_plus_axis = "nul"
input_player3_l_y_minus = "nul"
input_player3_l_y_minus_btn = "nul"
input_player3_l_y_minus_axis = "nul"
input_player3_r_x_plus = "nul"
input_player3_r_x_plus_btn = "nul"
input_player3_r_x_plus_axis = "nul"
input_player3_r_x_minus = "nul"
input_player3_r_x_minus_btn = "nul"
input_player3_r_x_minus_axis = "nul"
input_player3_r_y_plus = "nul"
input_player3_r_y_plus_btn = "nul"
input_player3_r_y_plus_axis = "nul"
input_player3_r_y_minus = "nul"
input_player3_r_y_minus_btn = "nul"
input_player3_r_y_minus_axis = "nul"
input_player3_turbo = "nul"
input_player3_turbo_btn = "nul"
input_player3_turbo_axis = "nul"
input_player4_b = "nul"
input_player4_b_btn = "nul"
input_player4_b_axis = "nul"
input_player4_y = "nul"
input_player4_y_btn = "nul"
input_player4_y_axis = "nul"
input_player4_select = "nul"
input_player4_select_btn = "nul"
input_player4_select_axis = "nul"
input_player4_start = "nul"
input_player4_start_btn = "nul"
input_player4_start_axis = "nul"
input_player4_up = "nul"
input_player4_up_btn = "nul"
input_player4_up_axis = "nul"
input_player4_down = "nul"
input_player4_down_btn = "nul"
input_player4_down_axis = "nul"
input_player4_left = "nul"
input_player4_left_btn = "nul"
input_player4_left_axis = "nul"
input_player4_right = "nul"
input_player4_right_btn = "nul"
input_player4_right_axis = "nul"
input_player4_a = "nul"
input_player4_a_btn = "nul"
input_player4_a_axis = "nul"
input_player4_x = "nul"
input_player4_x_btn = "nul"
input_player4_x_axis = "nul"
input_player4_l = "nul"
input_player4_l_btn = "nul"
input_player4_l_axis = "nul"
input_player4_r = "nul"
input_player4_r_btn = "nul"
input_player4_r_axis = "nul"
input_player4_l2 = "nul"
input_player4_l2_btn = "nul"
input_player4_l2_axis = "nul"
input_player4_r2 = "nul"
input_player4_r2_btn = "nul"
input_player4_r2_axis = "nul"
input_player4_l3 = "nul"
input_player4_l3_btn = "nul"
input_player4_l3_axis = "nul"
input_player4_r3 = "nul"
input_player4_r3_btn = "nul"
input_player4_r3_axis = "nul"
input_player4_l_x_plus = "nul"
input_player4_l_x_plus_btn = "nul"
input_player4_l_x_plus_axis = "nul"
input_player4_l_x_minus = "nul"
input_player4_l_x_minus_btn = "nul"
input_player4_l_x_minus_axis = "nul"
input_player4_l_y_plus = "nul"
input_player4_l_y_plus_btn = "nul"
input_player4_l_y_plus_axis = "nul"
input_player4_l_y_minus = "nul"
input_player4_l_y_minus_btn = "nul"
input_player4_l_y_minus_axis = "nul"
input_player4_r_x_plus = "nul"
input_player4_r_x_plus_btn = "nul"
input_player4_r_x_plus_axis = "nul"
input_player4_r_x_minus = "nul"
input_player4_r_x_minus_btn = "nul"
input_player4_r_x_minus_axis = "nul"
input_player4_r_y_plus = "nul"
input_player4_r_y_plus_btn = "nul"
input_player4_r_y_plus_axis = "nul"
input_player4_r_y_minus = "nul"
input_player4_r_y_minus_btn = "nul"
input_player4_r_y_minus_axis = "nul"
input_player4_turbo = "nul"
input_player4_turbo_btn = "nul"
input_player4_turbo_axis = "nul"
input_player5_b = "nul"
input_player5_b_btn = "nul"
input_player5_b_axis = "nul"
input_player5_y = "nul"
input_player5_y_btn = "nul"
input_player5_y_axis = "nul"
input_player5_select = "nul"
input_player5_select_btn = "nul"
input_player5_select_axis = "nul"
input_player5_start = "nul"
input_player5_start_btn = "nul"
input_player5_start_axis = "nul"
input_player5_up = "nul"
input_player5_up_btn = "nul"
input_player5_up_axis = "nul"
input_player5_down = "nul"
input_player5_down_btn = "nul"
input_player5_down_axis = "nul"
input_player5_left = "nul"
input_player5_left_btn = "nul"
input_player5_left_axis = "nul"
input_player5_right = "nul"
input_player5_right_btn = "nul"
input_player5_right_axis = "nul"
input_player5_a = "nul"
input_player5_a_btn = "nul"
input_player5_a_axis = "nul"
input_player5_x = "nul"
input_player5_x_btn = "nul"
input_player5_x_axis = "nul"
input_player5_l = "nul"
input_player5_l_btn = "nul"
input_player5_l_axis = "nul"
input_player5_r = "nul"
input_player5_r_btn = "nul"
input_player5_r_axis = "nul"
input_player5_l2 = "nul"
input_player5_l2_btn = "nul"
input_player5_l2_axis = "nul"
input_player5_r2 = "nul"
input_player5_r2_btn = "nul"
input_player5_r2_axis = "nul"
input_player5_l3 = "nul"
input_player5_l3_btn = "nul"
input_player5_l3_axis = "nul"
input_player5_r3 = "nul"
input_player5_r3_btn = "nul"
input_player5_r3_axis = "nul"
input_player5_l_x_plus = "nul"
input_player5_l_x_plus_btn = "nul"
input_player5_l_x_plus_axis = "nul"
input_player5_l_x_minus = "nul"
input_player5_l_x_minus_btn = "nul"
input_player5_l_x_minus_axis = "nul"
input_player5_l_y_plus = "nul"
input_player5_l_y_plus_btn = "nul"
input_player5_l_y_plus_axis = "nul"
input_player5_l_y_minus = "nul"
input_player5_l_y_minus_btn = "nul"
input_player5_l_y_minus_axis = "nul"
input_player5_r_x_plus = "nul"
input_player5_r_x_plus_btn = "nul"
input_player5_r_x_plus_axis = "nul"
input_player5_r_x_minus = "nul"
input_player5_r_x_minus_btn = "nul"
input_player5_r_x_minus_axis = "nul"
input_player5_r_y_plus = "nul"
input_player5_r_y_plus_btn = "nul"
input_player5_r_y_plus_axis = "nul"
input_player5_r_y_minus = "nul"
input_player5_r_y_minus_btn = "nul"
input_player5_r_y_minus_axis = "nul"
input_player5_turbo = "nul"
input_player5_turbo_btn = "nul"
input_player5_turbo_axis = "nul"
input_player6_b = "nul"
input_player6_b_btn = "nul"
input_player6_b_axis = "nul"
input_player6_y = "nul"
input_player6_y_btn = "nul"
input_player6_y_axis = "nul"
input_player6_select = "nul"
input_player6_select_btn = "nul"
input_player6_select_axis = "nul"
input_player6_start = "nul"
input_player6_start_btn = "nul"
input_player6_start_axis = "nul"
input_player6_up = "nul"
input_player6_up_btn = "nul"
input_player6_up_axis = "nul"
input_player6_down = "nul"
input_player6_down_btn = "nul"
input_player6_down_axis = "nul"
input_player6_left = "nul"
input_player6_left_btn = "nul"
input_player6_left_axis = "nul"
input_player6_right = "nul"
input_player6_right_btn = "nul"
input_player6_right_axis = "nul"
input_player6_a = "nul"
input_player6_a_btn = "nul"
input_player6_a_axis = "nul"
input_player6_x = "nul"
input_player6_x_btn = "nul"
input_player6_x_axis = "nul"
input_player6_l = "nul"
input_player6_l_btn = "nul"
input_player6_l_axis = "nul"
input_player6_r = "nul"
input_player6_r_btn = "nul"
input_player6_r_axis = "nul"
input_player6_l2 = "nul"
input_player6_l2_btn = "nul"
input_player6_l2_axis = "nul"
input_player6_r2 = "nul"
input_player6_r2_btn = "nul"
input_player6_r2_axis = "nul"
input_player6_l3 = "nul"
input_player6_l3_btn = "nul"
input_player6_l3_axis = "nul"
input_player6_r3 = "nul"
input_player6_r3_btn = "nul"
input_player6_r3_axis = "nul"
input_player6_l_x_plus = "nul"
input_player6_l_x_plus_btn = "nul"
input_player6_l_x_plus_axis = "nul"
input_player6_l_x_minus = "nul"
input_player6_l_x_minus_btn = "nul"
input_player6_l_x_minus_axis = "nul"
input_player6_l_y_plus = "nul"
input_player6_l_y_plus_btn = "nul"
input_player6_l_y_plus_axis = "nul"
input_player6_l_y_minus = "nul"
input_player6_l_y_minus_btn = "nul"
input_player6_l_y_minus_axis = "nul"
input_player6_r_x_plus = "nul"
input_player6_r_x_plus_btn = "nul"
input_player6_r_x_plus_axis = "nul"
input_player6_r_x_minus = "nul"
input_player6_r_x_minus_btn = "nul"
input_player6_r_x_minus_axis = "nul"
input_player6_r_y_plus = "nul"
input_player6_r_y_plus_btn = "nul"
input_player6_r_y_plus_axis = "nul"
input_player6_r_y_minus = "nul"
input_player6_r_y_minus_btn = "nul"
input_player6_r_y_minus_axis = "nul"
input_player6_turbo = "nul"
input_player6_turbo_btn = "nul"
input_player6_turbo_axis = "nul"
input_player7_b = "nul"
input_player7_b_btn = "nul"
input_player7_b_axis = "nul"
input_player7_y = "nul"
input_player7_y_btn = "nul"
input_player7_y_axis = "nul"
input_player7_select = "nul"
input_player7_select_btn = "nul"
input_player7_select_axis = "nul"
input_player7_start = "nul"
input_player7_start_btn = "nul"
input_player7_start_axis = "nul"
input_player7_up = "nul"
input_player7_up_btn = "nul"
input_player7_up_axis = "nul"
input_player7_down = "nul"
input_player7_down_btn = "nul"
input_player7_down_axis = "nul"
input_player7_left = "nul"
input_player7_left_btn = "nul"
input_player7_left_axis = "nul"
input_player7_right = "nul"
input_player7_right_btn = "nul"
input_player7_right_axis = "nul"
input_player7_a = "nul"
input_player7_a_btn = "nul"
input_player7_a_axis = "nul"
input_player7_x = "nul"
input_player7_x_btn = "nul"
input_player7_x_axis = "nul"
input_player7_l = "nul"
input_player7_l_btn = "nul"
input_player7_l_axis = "nul"
input_player7_r = "nul"
input_player7_r_btn = "nul"
input_player7_r_axis = "nul"
input_player7_l2 = "nul"
input_player7_l2_btn = "nul"
input_player7_l2_axis = "nul"
input_player7_r2 = "nul"
input_player7_r2_btn = "nul"
input_player7_r2_axis = "nul"
input_player7_l3 = "nul"
input_player7_l3_btn = "nul"
input_player7_l3_axis = "nul"
input_player7_r3 = "nul"
input_player7_r3_btn = "nul"
input_player7_r3_axis = "nul"
input_player7_l_x_plus = "nul"
input_player7_l_x_plus_btn = "nul"
input_player7_l_x_plus_axis = "nul"
input_player7_l_x_minus = "nul"
input_player7_l_x_minus_btn = "nul"
input_player7_l_x_minus_axis = "nul"
input_player7_l_y_plus = "nul"
input_player7_l_y_plus_btn = "nul"
input_player7_l_y_plus_axis = "nul"
input_player7_l_y_minus = "nul"
input_player7_l_y_minus_btn = "nul"
input_player7_l_y_minus_axis = "nul"
input_player7_r_x_plus = "nul"
input_player7_r_x_plus_btn = "nul"
input_player7_r_x_plus_axis = "nul"
input_player7_r_x_minus = "nul"
input_player7_r_x_minus_btn = "nul"
input_player7_r_x_minus_axis = "nul"
input_player7_r_y_plus = "nul"
input_player7_r_y_plus_btn = "nul"
input_player7_r_y_plus_axis = "nul"
input_player7_r_y_minus = "nul"
input_player7_r_y_minus_btn = "nul"
input_player7_r_y_minus_axis = "nul"
input_player7_turbo = "nul"
input_player7_turbo_btn = "nul"
input_player7_turbo_axis = "nul"
input_player8_b = "nul"
input_player8_b_btn = "nul"
input_player8_b_axis = "nul"
input_player8_y = "nul"
input_player8_y_btn = "nul"
input_player8_y_axis = "nul"
input_player8_select = "nul"
input_player8_select_btn = "nul"
input_player8_select_axis = "nul"
input_player8_start = "nul"
input_player8_start_btn = "nul"
input_player8_start_axis = "nul"
input_player8_up = "nul"
input_player8_up_btn = "nul"
input_player8_up_axis = "nul"
input_player8_down = "nul"
input_player8_down_btn = "nul"
input_player8_down_axis = "nul"
input_player8_left = "nul"
input_player8_left_btn = "nul"
input_player8_left_axis = "nul"
input_player8_right = "nul"
input_player8_right_btn = "nul"
input_player8_right_axis = "nul"
input_player8_a = "nul"
input_player8_a_btn = "nul"
input_player8_a_axis = "nul"
input_player8_x = "nul"
input_player8_x_btn = "nul"
input_player8_x_axis = "nul"
input_player8_l = "nul"
input_player8_l_btn = "nul"
input_player8_l_axis = "nul"
input_player8_r = "nul"
input_player8_r_btn = "nul"
input_player8_r_axis = "nul"
input_player8_l2 = "nul"
input_player8_l2_btn = "nul"
input_player8_l2_axis = "nul"
input_player8_r2 = "nul"
input_player8_r2_btn = "nul"
input_player8_r2_axis = "nul"
input_player8_l3 = "nul"
input_player8_l3_btn = "nul"
input_player8_l3_axis = "nul"
input_player8_r3 = "nul"
input_player8_r3_btn = "nul"
input_player8_r3_axis = "nul"
input_player8_l_x_plus = "nul"
input_player8_l_x_plus_btn = "nul"
input_player8_l_x_plus_axis = "nul"
input_player8_l_x_minus = "nul"
input_player8_l_x_minus_btn = "nul"
input_player8_l_x_minus_axis = "nul"
input_player8_l_y_plus = "nul"
input_player8_l_y_plus_btn = "nul"
input_player8_l_y_plus_axis = "nul"
input_player8_l_y_minus = "nul"
input_player8_l_y_minus_btn = "nul"
input_player8_l_y_minus_axis = "nul"
input_player8_r_x_plus = "nul"
input_player8_r_x_plus_btn = "nul"
input_player8_r_x_plus_axis = "nul"
input_player8_r_x_minus = "nul"
input_player8_r_x_minus_btn = "nul"
input_player8_r_x_minus_axis = "nul"
input_player8_r_y_plus = "nul"
input_player8_r_y_plus_btn = "nul"
input_player8_r_y_plus_axis = "nul"
input_player8_r_y_minus = "nul"
input_player8_r_y_minus_btn = "nul"
input_player8_r_y_minus_axis = "nul"
input_player8_turbo = "nul"
input_player8_turbo_btn = "nul"
input_player8_turbo_axis = "nul"
core_specific_config = "false"
libretro_log_level = "0"
log_verbosity = "false"
perfcnt_enable = "false"
libretro_directory = ""
libretro_info_path = ""
cheat_database_path = ""
audio_device = ""
audio_dsp_plugin = ""
extraction_directory = ""
video_filter = ""
game_history_path = ""
input_overlay = ""
netplay_nickname = ""
netplay_ip_address = ""
input_joypad_driver = ""
input_keyboard_layout = ""
Habe euch mal meine komplette retroarch.cfg mit eingefügt. Aktuell ist der XBOX360- Controller konfiguriert.
Habe den PI auch in versch. Overclock- Modus versetzt. Hat trotzdem nicht funktioniert. Es kommt nicht mal ein Overlaytext wie zb. bei rewind- da kommt unten links im Spiel ein Text, das dieser Modus aktiviert ist.
Habt ihr eine Idee, an was es liegen könnte?
VG
Olaf
