Hallo Forum,
ich versuche auf meinem System: Raspberry Pi 2 B+, xbian den Sundtek Sky TV Ultimate IV 2015 (DVB-S/S2) zum Laufen zu bringen. Den Treiber habe ich laut Sundtek-Wiki installiert.
xbian@xbianrpi2 ~ $ /opt/bin/mediaclient -e
**** List of Media Hardware Devices ****
device 0: [Sundtek SkyTV Ultimate IV (2015)] DVB-S/S2, ANALOG-TV, REMOTE-CONTROL, OSS-AUDIO
[INFO]:
STATUS: STANDBY
[BUS]:
[SERIAL]:
[DVB-S/S2]:
FESTATUS: STANDBY
LNBVOLTAGE: DISABLED
LNBSUPPLY: USBPOWER
LNBSTATUS: OK
FRONTEND: /dev/dvb/adapter0/frontend0
DVR: /dev/dvb/adapter0/dvr0
DMX: /dev/dvb/adapter0/demux0
[ANALOG-TV]:
VIDEO0: /dev/video0
VBI0: /dev/vbi0
[REMOTECONTROL]:
INPUT0: /dev/mediainput0
[OSS]:
OSS0: /dev/dsp0
Ich kann aber kein PVR-Addon installieren. Fehlermeldung: Verbindung unterbrochen. Hier noch meine sundtek.conf:
# ----- GLOBAL SECTION -----
#Set loglevel for logging to /var/log/mediasrv.log
#autoupdate=[on|off] #enable automatic driver update, default off
loglevel=full #default: off
#max .. little bit more debug
#pluginpath=/path/to/drivers #set path to drivers
#dvb_api_version=x.y #default API version will be parsed from
#/usr/include/linux/dvb/version.h, if no such file is
#available the latest internally supported API version will be
#used (which will be quite new)
#audio_skip_bytes=N #when changing analogTV channels,
#skip N bytes to suppress audio noise
#bulk_notification[on|off] #default off, bulk_notification will only trigger device_attach once
#after the the first device scan when the driver is started up
#after this first scan, the notification will be triggered
#normally again for each device.
#for example when 2 devices are attached to the system only one
#notification will be triggered initially, any at a later time
#attached device will generate another device_attach notification
#by default each device will call the script which is set up with
#device_attach
#use_tvvideo=[on|off] #use /dev/tvvideoN instead of /dev/video
#this works around a new Adobe Flash bug in 2012, where flash crashes
#if files (/dev/videoN) other than /dev/video0 are available
#use_hwpidfilter=[on|off] #For DVB-C, DVB-T, DVB-S/S2
#enable PID filter, please be careful with that, there are only 15 HW Pid filters available
#when more than 15 pids are set up the pid filter will be disabled automatically
#dmhwpidfilter=[on|off] #default on, in some cases off might be useful to disable hw pid filter for settopboxes
#if you get a black image when capturing a TV channel and watching another channel on the
#same transponder - try this option and reboot
#usb_transaction_delay=[0-20] #throttle the USB setup transactions, this can solve problems with weak USB stacks for
#example for embedded boards, unit is milliseconds
#usb_timeout=[0 - N] #USB timeout for each transaction in milliseconds, 0 default infinite
#voltage_tone_off=[1 or 0] #0 .. default, normal behaviour
#1 .. force DVB-S/S2 to not use any Voltage or Tone (ignore any user parameters)
#ir_disabled=[1 or 0] #0 .. enable remote control polling, the driver will permanently check for remote control keys
#1 .. disable remote control polling, might fix bugs with weak USB stacks on embedded boards
#Enable listening on network
#enablenetwork=[on|off] #default: off
#Lowest adapter number to start with, e.g. /dev/dvb/adapter5/frontend0
#first_adapter=5
#Lowest videodevice number to start with, e.g. /dev/video5
#first_videodev=5
#Call attach script when new device appears
#device_attach=[PATH_TO_SCRIPT] [PARAMETER|DEVID] #"DEVID" will automatically be replaced with the device ID
#Call detach script when device disappears
#device_detach=[PATH_TO_SCRIPT] [PARAMETER|DEVID] #"DEVID" will automatically be replaced with the device ID
#Dreambox especially for DM800HD (not SE!)
#vtuner_acceleration=[on|off] #default off, accelerate Dreambox 800HD datatransfer between USB Stick and
#DM800HD
# ----- Section for adapter with [SERIALNUMBER] -----
#Get adapter serial number with /opt/bin/mediaclient -e
#[SERIALNUMBER]
#Description register as dreambox tuner
#dreambox_support_fe1=[on|off] #default: off
#Infrared protocol to use
#ir_protocol=[RC5|NEC|RC6] #default: NEC
#Keymap to use, e.g. "/lib/udev/rc_keymaps/vp702x"
#rcmap=[PATH_TO_KEYMAP] #default: keymap which comes with the device
#Choose initial DVB mode for hybrid DVB-T/DVB-C devices only
#initial_dvb_mode=[DVBC|DVBT]
#disable_analogtv=[0|1] #disable initialization of analogTV Frontend
#Initial Audio Volume level for DVB-C/T Hybrid devices
#volume=[0-127] #default: 118, this applies to DVB-C/T/AnalogTV devices
#volume1=[0-255] #default: 219, this applies to DVB-T/AnalogTV devices
# please note too high volume might overdrive the audio IC
# 219 or lower is recommended, although it's based on your
# situation; some devices only support that for FM-Radio
#soft_volume=[0-100] #software volume adjustment, some devices don't support
# hardware adjustment, v4l2-ctl -l -d /dev/videoN will show
# up if software volume adjustment is available, values
# higher than 100 will amplify the audiostream
# WSS callback (see http://en.wikipedia.org/wiki/Widescreen_signaling)
# trigger script when the videoformat changes between 16:9 or 4:3
#wss_callback=[scriptname]
# WSS_4_3_FULL
# WSS_14_9_LETTERBOX_CENTRE
# WSS_14_9_LETTERBOX_TOP
# WSS_16_9_LETTERBOX_CENTRE
# WSS_16_9_LETTERBOX_TOP
# WSS_16_9_LETTERBOX_DEEPER
# WSS_14_9_FULL_HEIGHT_4_3
# WSS_16_9_FULL_HEIGHT_16_9
# WSS_UNABLE_TO_DEMODULATE
#Timeout in ms after that WSS_UNABLE_TO_DEMODULATE will be called
#wss_demodulation_timeout=[MILLISECONDS]
#vtuner_skip0=vtuner0 # skip /dev/misc/vtuner0 can also be vtunerN
#vtuner_skip1=vtuner1 # skip /dev/misc/vtuner1 can also be vtunerN
#ts_settle_timeout=N # block sending TS data to the application for N milliseconds (0-4000), default 0
#fe_helper=/path/to/channellist # override frequency setup and use parameters from channellist
# VDR channellists can be used here (eg. created by w_scan)
# this somewhat guarantees high speed channel switching
# when used with a lousy player
# Astra 19.2 Channellist: 1)
#disable_crc=on # disable driver internal CRC check for PSI tables
#standby_timeout=0-50000 # set standby timeout default is 15 Seconds (15000) value in milliseconds
### UNICABLE ###
#unicable_frequency=N # Unicable Frequency
#unicable_satcr=N # SaTCR
#alsa_blocking=off # default is on, off might be able to avoid some issues with
# weird alsa drivers
# following is the network section, the 2 given ip addresses are IPTV sample servers
#[NETWORK]
#device=192.168.0.1:0
#device=192.168.0.1:1
Als Server-ID habe ich im Plugin 127.0.0.1 eingetragen, kein User, kein Passwort.
Dann habe ich versucht /opt/bin/mediasrv als Dämon zu starten aber mit dem gleichen Ergebnis. Kann mir jemand helfen?
Vielen Dank im Voraus
CMLi
